メインコンテンツにスキップ
ヘルプ
Samsung L100 flash assembly replacement
  • 作成者: Adriel
  • 所要時間: 15分
  • 難易度: 普通
Flash bulb soldered to circuit board with capacitor, so it is not possible to only replace flash bulbs.
手順 1 Flash Circuit Board  ¶
Remove the screws holding the circuit board.
  • Remove the screws holding the circuit board.
  • After you remove the screws, carefully remove the circuit board.
手順 2  ¶
Remove the front cover, it comes off easily. Buttons might fall out when you remove the front cover.
手順 2  ¶
  • Remove the front cover, it comes off easily.
  • Buttons might fall out when you remove the front cover.
手順 3  ¶
Face camera towards you.
手順 3  ¶
  • Face camera towards you.
  • Remove the two screws from circuit board on the left side of the lens.
手順 4  ¶
Carefully hold up the circuit board, while it's still connected to the camera.
手順 4  ¶
  • Carefully hold up the circuit board, while it's still connected to the camera.
  • Remove all five screws that's on top of the camera.
手順 5  ¶
Carefully push up the top of the circuit board. Pull up flash circuit board from top of camera. Pull up flash circuit board from top of camera.
手順 5  ¶
  • Carefully push up the top of the circuit board.
  • Pull up flash circuit board from top of camera.
