メインコンテンツにスキップ
ヘルプ
Managing Texas Instruments TI-92 Keyboard
一貫性のない画像
一貫性のない画像
このガイドの画像を必要条件ガイドとより一致するように変更するとさらに素晴らしくなります。
手順の記述もれ
手順の記述もれ
申し訳ございませんがこのガイドは、いくつかの重要なステップが不足しています。
In this guide we will show you how to access the keyboard.
手順 1 Keyboard  ¶
Here we will use the front panel, separate from the motherboard Make sure not to tilt this part unless you want to remove all the keys from the face plate.
手順 1 Keyboard  ¶
  • Here we will use the front panel, separate from the motherboard
  • Make sure not to tilt this part unless you want to remove all the keys from the face plate.
  • Remove the rubber contact lying on top of the keys.
手順 2  ¶
With the rubber contact removed the keys can now be removed to be replaced, cleaned, or manipulated in other ways.
手順 2  ¶
  • With the rubber contact removed the keys can now be removed to be replaced, cleaned, or manipulated in other ways.
  • To aid the removal of individual keys you can use the Ipod Opening Tool or preferably a pair of tweezers.
手順 3  ¶
When placing the keys back into the faceplate you have to make sure that they are going in the right direction. You can tell which way is up by a semicircular extrusion on the back of a key. The gray and blue keys have the extrusion on the upper left hole looking at the back of the key.
手順 3  ¶
  • When placing the keys back into the faceplate you have to make sure that they are going in the right direction.
  • You can tell which way is up by a semicircular extrusion on the back of a key.
  • The gray and blue keys have the extrusion on the upper left hole looking at the back of the key.
  • The black keys on the other hand have the extrusions on the lower left hole looking at the back of the key.
手順 4  ¶
Use the pictures shown here as guides for where the keys should go if the keys fell out or you simply chose to remove them. Use the pictures shown here as guides for where the keys should go if the keys fell out or you simply chose to remove them. Use the pictures shown here as guides for where the keys should go if the keys fell out or you simply chose to remove them.
手順 4  ¶
  • Use the pictures shown here as guides for where the keys should go if the keys fell out or you simply chose to remove them.
