メインコンテンツにスキップ
ヘルプ
Canon PowerShot SD450 Lens Assembly Replacement
間違いの指摘
間違いの指摘
このガイドは最適な校正が必要です。校正の注釈を付けたり訂正することにご協力ください。
続きが抜けています
続きが抜けています
このガイドはどのようにしてプロセスを始めるかの情報が抜けています。必要条件ガイドを作成しましょう!
手順の記述もれ
手順の記述もれ
申し訳ございませんがこのガイドは、いくつかの重要なステップが不足しています。
This guide will walk you through a lens assembly replacement procedure.
セクション
ツール
手順 1 Lens Assembly  ¶
Remove the screw at the upper right-hand corner of the LCD screen
  • Remove the screw at the upper right-hand corner of the LCD screen
手順 2  ¶
Remove the function buttons by sliding the spudger underneath the black rubber and lifting up.
手順 2  ¶
  • Remove the function buttons by sliding the spudger underneath the black rubber and lifting up.
手順 3  ¶
Lift up the LCD screen WITHOUT removing it completely. The screen is still connected to the camera via a backlight ribbon underneath.
手順 3  ¶
  • Lift up the LCD screen WITHOUT removing it completely. The screen is still connected to the camera via a backlight ribbon underneath.
手順 4  ¶
Remove the last screw holding the tripod mount to the case. The LCD ribbon threads under the mount, so upon reinstallation, the ribbon will need to be threaded through before the mount is reattached. Take note of the tripod mount orientation.
手順 4  ¶
  • Remove the last screw holding the tripod mount to the case. The LCD ribbon threads under the mount, so upon reinstallation, the ribbon will need to be threaded through before the mount is reattached. Take note of the tripod mount orientation.
手順 5  ¶
Pull the back light ribbon from it's socket to remove the LCD completely. There is a little hole you can stick the spudger into to help release the ribbon.
手順 5  ¶
  • Pull the back light ribbon from it's socket to remove the LCD completely. There is a little hole you can stick the spudger into to help release the ribbon.
手順 6  ¶
Lift up the black tape from the right corner to expose the LED Push the out from the top of the camera, pulling away from the direction of the lens.
手順 6  ¶
  • Lift up the black tape from the right corner to expose the LED
  • Push the out from the top of the camera, pulling away from the direction of the lens.
手順 7  ¶
Remove the three screws which secure the lens assembly to the main chassis.
手順 7  ¶
  • Remove the three screws which secure the lens assembly to the main chassis.
手順 8  ¶
Remove the lens carefully from the chassis. You're done! Remove the lens carefully from the chassis. You're done!
手順 8  ¶
  • Remove the lens carefully from the chassis. You're done!
