ヘルプ
Gateway SA1 Disk Drive Replacement
This Guide will help you replace a Gateway Disk Drive.
セクション
ツール
関連部品
手順 1 Disk Drive  ¶
Unscrew the marked 5.9 mm Philips screw.
手順 1 Disk Drive  ¶
  • Unscrew the marked 5.9 mm Philips screw.
手順 2  ¶
Use the spudger to pry out the Disk dive.
手順 2  ¶
  • Use the spudger to pry out the Disk dive.
手順 3  ¶
The disk drive should easily detach and can now be replaced.
手順 3  ¶
  • The disk drive should easily detach and can now be replaced.
