メインコンテンツにスキップ
ヘルプ
Disassembling Cambridge Audio A3i Case
  • 作成者: Colby
  • 所要時間: 15分
  • 難易度: 簡単
This guide describes the steps to opening the case.
手順 1 Case  ¶
Remove 2 screws from each side of the amplifier.
手順 1 Case  ¶
  • Remove 2 screws from each side of the amplifier.
手順 2  ¶
Remove 2 screws on rear of device. Slide top cover up and back from main case.
手順 2  ¶
  • Remove 2 screws on rear of device. Slide top cover up and back from main case.
手順 3  ¶
Remove 3 screws on bottom of case. Remove 13 screws on rear panel.
手順 3  ¶
  • Remove 3 screws on bottom of case.
  • Remove 13 screws on rear panel.
  • Do not move the rear panel too far, as the power cord is still connected.
手順 4  ¶
Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
手順 4  ¶
  • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
  • It may require some wiggling, but it should slip out of the hole and then off of the cord.
