メインコンテンツにスキップ
ヘルプ
Sony Cyber-shot DSC-W150 LCD Screen Replacement
文法の修正
文法の修正
あなたの中にある日本語能力を呼び起こし、このガイドの文法に磨きをかけましょう。
メンバーによる寄稿ガイド
メンバーによる寄稿ガイド
私たちのコミュニティーの素晴らしいメンバーがこのガイドを作成しました。これはiFixitスタッフによって管理されていません。
不適切なツール
不適切なツール
画像と/やテキスト中に正しい工具を使用することでこのガイドがより良くなります。
手順の記述もれ
手順の記述もれ
申し訳ございませんがこのガイドは、いくつかの重要なステップが不足しています。
  • 作成者: Brent Clavin
  • 所要時間: 15 - 20 分
  • 難易度: 難しい
Replacing a defective LCD screen.
手順 1 LCD Screen  ¶
Remove the last screw holding the LCD/control panel to the rest of the camera on the right hand side. Looking at the right side of the camera, this last screw is in the bottom left corner. (There were two other screws that were removed when taking the back cover off, thus it is important to pay attention to which hole this screw comes out of for reassembly.)
手順 1 LCD Screen  ¶
  • Remove the last screw holding the LCD/control panel to the rest of the camera on the right hand side. Looking at the right side of the camera, this last screw is in the bottom left corner. (There were two other screws that were removed when taking the back cover off, thus it is important to pay attention to which hole this screw comes out of for reassembly.)
手順 2  ¶
At this point, all screws on the left and right sides of the camera should be removed. Paying careful attention to the right side's electrical wiring, gently pull the left side of the LCD plate away from the rest of the camera.
手順 2  ¶
  • At this point, all screws on the left and right sides of the camera should be removed.
  • Paying careful attention to the right side's electrical wiring, gently pull the left side of the LCD plate away from the rest of the camera.
  • DO NOT detach the electrical wiring connecting the right side of the LCD and the camera.
手順 3  ¶
NOTE: This picture is simply used to identify the action required to release the electrical ribbons, but not the proper location for this step.
手順 3  ¶
  • NOTE: This picture is simply used to identify the action required to release the electrical ribbons, but not the proper location for this step.
  • This step applies to the larger electrical ribbon connecting the LCD screen and circuit board.
  • Using a spudger, wedge the flat tipped end between the black bar and the circuit board.
  • Carefully lift the black bar into the vertical position.
手順 4  ¶
After raising the black bar, the electrical ribbon is free from its port.
手順 4  ¶
  • After raising the black bar, the electrical ribbon is free from its port.
  • Use tweezers to carefully pull larger electrical ribbon from its circuit board port.
手順 5  ¶
The smaller electrical ribbon, to the left of the larger ribbon, does not have a black bar securing it in place.
手順 5  ¶
  • The smaller electrical ribbon, to the left of the larger ribbon, does not have a black bar securing it in place.
  • Use tweezers to carefully pull smaller electrical ribbon from its circuit board port.
手順 6  ¶
Desolder the small electrical ribbon that connects the control panel to the LCD screen.
手順 6  ¶
  • Desolder the small electrical ribbon that connects the control panel to the LCD screen.
  • Now the LCD/control panel is completely removed from the part and ready to be replaced.
