メインコンテンツにスキップ
ヘルプ
Motorola Talkabout FV700R Front Faceplate Replacement
In order to replace many components, the radio needs to be opened. This guide will show how to effectively open the radio without breaking any parts.
  • 作成者: Jack Harrison
  • 所要時間: 5 - 15 分
  • 難易度: 普通
The front faceplate protects the components inside the radio. To replace inside components, the front faceplate of the radio must be removed. Follow the steps below to properly open the radio.
セクション
手順 1 Front Faceplate  ¶
Remove the four 3 millimeter T6 Torx screws from the front of the radio.
  • Remove the four 3 millimeter T6 Torx screws from the front of the radio.
手順 2  ¶
Remove the four 3 millimeter T8 Torx screws from the back of the radio. Remove the four 3 millimeter T8 Torx screws from the back of the radio.
手順 2  ¶
  • Remove the four 3 millimeter T8 Torx screws from the back of the radio.
手順 3  ¶
Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides. Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna. Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
手順 3  ¶
  • Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
  • Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
手順 4  ¶
Gently pull the circuit board away from the front faceplate. Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
手順 4  ¶
  • Gently pull the circuit board away from the front faceplate.
  • Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
  • Do not touch the the button contacts on the circuit board (the button contacts are shown in the red box of the second picture). This can cause long-term damage to the radio unless you properly clean them (see Repairing Motorola TALKABOUT FV700 Two Way Radio Button Contacts Guide).
