メインコンテンツにスキップ
ヘルプ
Kodak EasyShare C713 Outer Case Replacement
おすすめのガイド
おすすめのガイド
このガイドはiFixitスタッフによって太鼓判が押されています。
Replace the Outer Case in your Kodak EasyShare C713.
  • 作成者: Taggart Ashby
  • 所要時間: 5 - 10 分
  • 難易度: 簡単
Use this guide to remove and replace front and back casing.
セクション
ツール
手順 1 Outer Case  ¶
Remove 7 screws from the outer case with a Phillips #00. All screws are 4.45mm. There are 2 screws on the port side.
手順 1 Outer Case  ¶
  • Remove 7 screws from the outer case with a Phillips #00.
  • All screws are 4.45mm.
  • There are 2 screws on the port side.
  • There are 2 screws on starboard side.
  • There are 3 screws on the bottom.
手順 2  ¶
Make sure the battery cap is "up". Pull the outer case off with your hands. Pull the outer case off with your hands.
手順 2  ¶
  • Make sure the battery cap is "up".
  • Pull the outer case off with your hands.
