メインコンテンツにスキップ
ヘルプ
Uniden TCX905 Home Button Replacement
高画質の画像が必要
高画質の画像が必要
よりよい画像があればこのガイドが改善されます。よければ新しい写真を撮影し、編集し、アップロードしてお手伝いください。
This guide will show the user how to replace the plastic home button in the center of the front face.
  • 作成者: Gary Pence
  • 所要時間: 5 - 10 分
  • 難易度: 普通
The home button is located in the center of the front side of the phone, just underneath the screen.
セクション
手順 1 Home Button  ¶
Remove the white plastic sheet covering the silicon button pad Remove the silicon button pad to access the home button and spring Note: Be mindful that the spring is small and sensitive and can be lost easily if not cautious
手順 1 Home Button  ¶
  • Remove the white plastic sheet covering the silicon button pad
  • Remove the silicon button pad to access the home button and spring
  • Note: Be mindful that the spring is small and sensitive and can be lost easily if not cautious
手順 2  ¶
Once the silicon button pad is removed, remove the spring from home button Finally, remove the home button from its setting in the front shell of the phone
手順 2  ¶
  • Once the silicon button pad is removed, remove the spring from home button
  • Finally, remove the home button from its setting in the front shell of the phone
