メインコンテンツにスキップ
ヘルプ
Sony Vaio VGN-FW21Z Power Adapter Replacement
How to take out the power adapter of the Sony Vaio VGN-FW21Z
  • 作成者: Jeffrey Bryan
  • 所要時間: 15分
  • 難易度: 普通
How to take out the power adapter of the Sony Vaio VGN-S260
セクション
ツール
手順 1 Power Adapter  ¶
Locate the yellow power adapter. Follow its wire to white logic board connector.
  • Locate the yellow power adapter.
  • Follow its wire to white logic board connector.
  • Pull out the wire from white logic board connector.
手順 2  ¶
Locate the screws on the fan filter casing. Remove these screws. Remove these screws.
手順 2  ¶
  • Locate the screws on the fan filter casing.
  • Remove these screws.
手順 3  ¶
Remove the screw next to the yellow power adapter. Lift out power adapter and fan filter.
手順 3  ¶
  • Remove the screw next to the yellow power adapter.
  • Lift out power adapter and fan filter.
