メインコンテンツにスキップ
ヘルプ
Disassembling Xbox 360 E Top Panel
Remove the top panel of the Xbox 360 E. Note: Disassembly of your Xbox 360 E will void your warranty.
  • 作成者: Jennifer
  • 所要時間: 5分
  • 難易度: 簡単
This guide is a prerequisite for replacing other parts of an Xbox 360 E.
ツール
手順 1 Top Panel  ¶
Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
手順 1 Top Panel  ¶
  • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
  • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
手順 2  ¶
Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
手順 2  ¶
  • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
  • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
手順 3  ¶
Continue sliding the spudger along the perimeter of the left grated face of the Xbox. Pull the top panel off. Pull the top panel off.
手順 3  ¶
  • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
  • Pull the top panel off.
