メインコンテンツにスキップ
ヘルプ
DualShock 4 Buttons Replacement
Replace/ clean the buttons on your Dualshock 4 controller.
  • 作成者: Mark
  • 所要時間: 20分
  • 難易度: 普通
Use this guide to replace or fix any buttons on the Dualshock 4 controller.
手順 1 Buttons  ¶
Remove the rubber covering concealing the buttons with your fingers. Use the metal tweezers to then remove the button from its slot. Use the metal tweezers to then remove the button from its slot.
手順 1 Buttons  ¶
  • Remove the rubber covering concealing the buttons with your fingers.
  • Use the metal tweezers to then remove the button from its slot.
手順 2  ¶
To remove the arrow key buttons, use the same process you used for the control buttons by removing the rubber cover and pulling the button out with metal tweezers. To remove the arrow key buttons, use the same process you used for the control buttons by removing the rubber cover and pulling the button out with metal tweezers. To remove the arrow key buttons, use the same process you used for the control buttons by removing the rubber cover and pulling the button out with metal tweezers.
手順 2  ¶
  • To remove the arrow key buttons, use the same process you used for the control buttons by removing the rubber cover and pulling the button out with metal tweezers.
手順 3  ¶
For the share and options buttons, use the metal tweezers to grasp and remove them. For the share and options buttons, use the metal tweezers to grasp and remove them.
手順 3  ¶
  • For the share and options buttons, use the metal tweezers to grasp and remove them.
手順 4  ¶
In order to remove the PS button on the controller, you must first remove the rubber cover with your fingers. Then using the metal tweezers, remove the PS button.
手順 4  ¶
  • In order to remove the PS button on the controller, you must first remove the rubber cover with your fingers.
  • Then using the metal tweezers, remove the PS button.
