メインコンテンツにスキップ
ヘルプ
Samsung Blast Keyboard Replacement
高画質の画像が必要
高画質の画像が必要
よりよい画像があればこのガイドが改善されます。よければ新しい写真を撮影し、編集し、アップロードしてお手伝いください。
多くの画像が必要
多くの画像が必要
幾つかの画像があればこのガイドの手順がより明確になるでしょう。
続きが抜けています
続きが抜けています
このガイドはどのようにしてプロセスを始めるかの情報が抜けています。必要条件ガイドを作成しましょう!
スライスとサイコロ
スライスとサイコロ
このガイドの手順は分割され必要条件ガイドのシリーズに含まれるべきです。
This guide will demonstrate how to replace the keyboard of a Samsung Blast.
  • 作成者: Jordan Taylor
  • 所要時間: 15 - 30 分
  • 難易度: 簡単
手順 1 At a Glance  ¶
Your phone should look like this before disassembly. Your phone should look like this before disassembly.
手順 1 At a Glance  ¶
  • Your phone should look like this before disassembly.
手順 2 Battery Case Removal  ¶
Remove the battery cover by sliding the back panel up. This will expose the battery. Remove the battery cover by sliding the back panel up. This will expose the battery.
  • Remove the battery cover by sliding the back panel up. This will expose the battery.
手順 3 Remove Battery/Sim card  ¶
Lift up the top portion of the battery and pull it out.
  • Lift up the top portion of the battery and pull it out.
  • Next, slide the sim card out of its socket and set it aside.
手順 4 Back Case Removal  ¶
Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case. The top two screws are connected to the back cover. They will not come off once unscrewed.
  • Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
  • The top two screws are connected to the back cover. They will not come off once unscrewed.
  • Remove the case by prying around the edges.
  • Note the positions of button pads for reassembly.
手順 5 Button Pads  ¶
Remove the buttons for the camera and volume. Remove the buttons for the camera and volume.
手順 5 Button Pads  ¶
  • Remove the buttons for the camera and volume.
手順 6 Motherboard Removal  ¶
Use a prying tool to detach the motherboard from main body. Carefully detach the motherboard from the two connectors. You could also use a pry tool for the second step.
  • Use a prying tool to detach the motherboard from main body.
  • Carefully detach the motherboard from the two connectors.
  • You could also use a pry tool for the second step.
  • Be careful with the motherboard as not to scrape or damage its components.
手順 7 Keyboard Pad Replacement  ¶
Slide the keyboard straight up to free it from its alignment pins. Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
  • Slide the keyboard straight up to free it from its alignment pins.
  • Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
