メインコンテンツにスキップ
ヘルプ
PowerBook G4 Aluminum 12" 867 MHz Heat Sink & Fan Replacement
  • 作成者: iRobot
  • 難易度: 難しい
The heat sink and fan together help to keep the processor cool and happy.
セクション
ファイル
手順 1 Heat Sink & Fan  ¶
Remove the single Phillips screw fastening the inverter cable.
  • Remove the single Phillips screw fastening the inverter cable.
手順 2  ¶
Disconnect the Bluetooth cable and deroute it.
手順 2  ¶
  • Disconnect the Bluetooth cable and deroute it.
手順 3  ¶
Peeling up yellow tape as necessary, remove the following 8 screws:
手順 3  ¶
  • Peeling up yellow tape as necessary, remove the following 8 screws:
  • One 4.5 mm Phillips on the right side of the heat sink.
  • Three 6 mm Phillips near the display.
  • Two large 7.5 mm Phillips with springs (don't forget to remove the springs). If the springs are not releasing, needle nose pliers can help get this done.
  • Two 13 mm screws from the left side of the heat sink and the right side of the fan.
手順 4  ¶
Remove the yellow tape to free the cable from the left side of the heat sink.
手順 4  ¶
  • Remove the yellow tape to free the cable from the left side of the heat sink.
手順 5  ¶
Disconnect the fan cable from the logic board.
手順 5  ¶
  • Disconnect the fan cable from the logic board.
手順 6  ¶
Remove the orange tape on the trackpad side of the fan to free the fan cable.
手順 6  ¶
  • Remove the orange tape on the trackpad side of the fan to free the fan cable.
手順 7  ¶
Grasp the heat sink near the copper conductor and lift it out of the computer, freeing it from tape and cables as necessary.
手順 7  ¶
  • Grasp the heat sink near the copper conductor and lift it out of the computer, freeing it from tape and cables as necessary.
  • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
