メインコンテンツにスキップ
ヘルプ
Removing PowerMac G4 M5183 DVD-ROM Drive Tray
Removing and replacing the DVD-ROM drive.
手順 1 DVD-ROM Drive  ¶
Removing the faceplate. On the inside of the case, find the two plastic tabs.
  • Removing the faceplate.
  • On the inside of the case, find the two plastic tabs.
  • While depressing the tabs, remove the faceplate by pulling and rotating outward.
手順 2  ¶
Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
手順 2  ¶
  • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
手順 3  ¶
Pull the drive out to allow access to the power and ribbon cables. Do not fully remove. Remove both the power and ribbon cable. Remove both the power and ribbon cable.
手順 3  ¶
  • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
  • Remove both the power and ribbon cable.
