メインコンテンツにスキップ
ヘルプ
Samsung Stratosphere Front Camera Replacement
This guide will teach you how to replace the front camera on the Samsung Stratosphere.
  • 作成者: Ryan
  • 所要時間: 35 - 45 分
  • 難易度: 普通
The front camera is on the same side as the phone's screen and is the only camera used to Skype on the Samsung Stratosphere.
セクション
手順 1 Front Camera  ¶
Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
手順 1 Front Camera  ¶
  • Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
  • Pry the keyboard away from the casing with the plastic opening tool.
  • The keyboard should come off with almost no force at all.
手順 2  ¶
Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
手順 2  ¶
  • Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
手順 3  ¶
Use the plastic opening tool to carefully loosen the golden metal plate.
手順 3  ¶
  • Use the plastic opening tool to carefully loosen the golden metal plate.
  • The golden metal plate is stuck to the rear panel with a strong adhesive, so a moderate amount of force may be needed.
手順 4  ¶
Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
手順 4  ¶
  • Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
  • Carefully take off the keyboard casing with your fingers.
  • The golden metal plate should fit through the wide slot of the casing.
手順 5  ¶
Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
手順 5  ¶
  • Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
  • The metal plate is attached to springs that offer a small amount of resistance, so it will snap into place.
手順 6  ¶
Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
手順 6  ¶
  • Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
手順 7  ¶
Insert the plastic opening tool into the groove at the top of the rear panel. Firmly slide the plastic opening tool all around the rear panel.  The panel will audibly snap as it comes apart.
手順 7  ¶
  • Insert the plastic opening tool into the groove at the top of the rear panel.
  • Firmly slide the plastic opening tool all around the rear panel. The panel will audibly snap as it comes apart.
  • These 2 pieces are attached well, so a significant amount of force is needed to separate them.
手順 8  ¶
Lift the flex cable and position it so the part containing the metal plate can come free.
手順 8  ¶
  • Lift the flex cable and position it so the part containing the metal plate can come free.
  • Pull the part containing the metal plate away from the rest of the rear panel.
手順 9  ¶
Use tweezers to loosen the front-facing camera from the plastic casing. Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
手順 9  ¶
  • Use tweezers to loosen the front-facing camera from the plastic casing.
  • Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
