メインコンテンツにスキップ
ヘルプ
HP Mini 110-1046NR Battery Replacement
This guide will explain how to replace a battery on an HP Mini 110
  • 作成者: Amos Hine
  • 所要時間: 20 秒
  • 難易度: とても簡単
The 3-Cell Lithium-Ion battery for the HP Mini 110 is attached to the bottom, rear edge of the netbook. Temporarily removing the battery is the first step in any disassembly procedure because it reduces the likelihood of electric shock and damage to the internal components.
手順 1 Battery  ¶
Power-off the netbook fully before attempting to remove the battery. Flip your netbook upside down, and locate the sliding tabs near the battery. Slide both tabs inward so that the battery visibly moves away from the case of the computer.
手順 1 Battery  ¶
  • Power-off the netbook fully before attempting to remove the battery.
  • Flip your netbook upside down, and locate the sliding tabs near the battery.
  • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
  • Release the tabs and pull the battery out.
