メインコンテンツにスキップ
ヘルプ
Palm Treo 600 Battery Replacement
Follow this guide if the battery is dysfunctional and you want to replace it.
セクション
ツール
手順 1 Battery  ¶
Using metal tweezers, unplug small white plug. Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
手順 1 Battery  ¶
  • Using metal tweezers, unplug small white plug.
  • Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
手順 2  ¶
Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
手順 2  ¶
  • Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
  • The battery may be glued to the phone.
