メインコンテンツにスキップ
ヘルプ
Velocity NoteMagix M10 A82 Cooling Fan Replacement
間違いの指摘
間違いの指摘
このガイドは最適な校正が必要です。校正の注釈を付けたり訂正することにご協力ください。
In this guide you will replace the cooling fan. This will involve removing several parts of the computer using two sizes of screw driver and a plastic opening tool. This guide can be easily completed in under one hour.
  • 作成者: Jaymes Lee
  • 所要時間: 1時間
  • 難易度: 普通
This guide will show how to safely remove the cooling fan from the NoteMagix M10 A82 netbook.
セクション
ツール
手順 1 Cooling Fan  ¶
Remove the eight 5.65mm Phillips #1 screws.
手順 1 Cooling Fan  ¶
  • Remove the eight 5.65mm Phillips #1 screws.
手順 2  ¶
Place the computer open and with the screen facing up on the table.
手順 2  ¶
  • Place the computer open and with the screen facing up on the table.
  • Remove the three 3.65mm Phillips #1 screws in the right hand corner. Also remove the mirrored set of screws on the left side.
手順 3  ¶
Remove the black and gray wires by gently grasping the wires where they connect to the motherboard and pulling up.
手順 3  ¶
  • Remove the black and gray wires by gently grasping the wires where they connect to the motherboard and pulling up.
手順 4  ¶
Using the plastic opening tool, pry the base of the cable connecting the screen to the motherboard upwards.
手順 4  ¶
  • Using the plastic opening tool, pry the base of the cable connecting the screen to the motherboard upwards.
手順 5  ¶
Remove the front cover plate by wedging the spudger underneath at the bottom edge of the computer and gently prying upwards while sliding the spudger around the base of the laptop. Remove the front cover plate by wedging the spudger underneath at the bottom edge of the computer and gently prying upwards while sliding the spudger around the base of the laptop.
手順 5  ¶
  • Remove the front cover plate by wedging the spudger underneath at the bottom edge of the computer and gently prying upwards while sliding the spudger around the base of the laptop.
手順 6  ¶
Remove the two 4.80mm Phillips #00 screws holding down the fan.
手順 6  ¶
  • Remove the two 4.80mm Phillips #00 screws holding down the fan.
手順 7  ¶
Remove the red, yellow, and black wires connecting the fan to the motherboard by placing your index finger underneath the wires where they connect to the motherboard, pinching the wires together with your thumb and index finger, and gently pulling the wires upwards. Remove the red, yellow, and black wires connecting the fan to the motherboard by placing your index finger underneath the wires where they connect to the motherboard, pinching the wires together with your thumb and index finger, and gently pulling the wires upwards.
手順 7  ¶
  • Remove the red, yellow, and black wires connecting the fan to the motherboard by placing your index finger underneath the wires where they connect to the motherboard, pinching the wires together with your thumb and index finger, and gently pulling the wires upwards.
