メインコンテンツにスキップ
ヘルプ
Palm v Outer Case Replacement
  • 作成者: Anthony Platt
  • 所要時間: 10 - 15 分
  • 難易度: 難しい
How remove the outer casing
手順 1 Outer Case  ¶
Lay device face down on surface.
手順 1 Outer Case  ¶
  • Lay device face down on surface.
手順 2  ¶
Heat the left and top edges with hairdryer for one minute. Move hairdryer back and forth to evenly heat up surface.
手順 2  ¶
  • Heat the left and top edges with hairdryer for one minute.
  • Move hairdryer back and forth to evenly heat up surface.
  • Caution: directly heating the screen can melt or distort the screen.
手順 3  ¶
Use tweezers to hold Palm right side down on it's side.
手順 3  ¶
  • Use tweezers to hold Palm right side down on it's side.
  • Use a plastic opening tool to pry open front and back casing.
  • If you are unable to open you may need to heat with hairdryer for longer.
  • Be sure not to touch case directly with fingers, it will be hot!
手順 4  ¶
Leave plastic opening tools in between front and back casing.
手順 4  ¶
  • Leave plastic opening tools in between front and back casing.
  • Rotate Palm and repeat steps 2 and 3 for right and back edges.
手順 5  ¶
Now pry open front and back casing with plastic opening tools. Separate front and back casing completely. Power button will fall off once front and back casing have been removed. Be sure not to lose it.
手順 5  ¶
  • Now pry open front and back casing with plastic opening tools.
  • Separate front and back casing completely.
  • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
