メインコンテンツにスキップ
ヘルプ
Acer AL2216W Power Supply Capacitor Replacement
潜在的に致命的です
潜在的に致命的です
このガイドに適切に従わなければ使用できなくなるか大きなダメージが残る可能性があります。最新の注意を払って全ての警告に従ってください!
メンバーによる寄稿ガイド
メンバーによる寄稿ガイド
私たちのコミュニティーの素晴らしいメンバーがこのガイドを作成しました。これはiFixitスタッフによって管理されていません。
WP Users: USE THE MOBILE SITE. THE INTRO DOES NOT WORK AND CONTAINS KEY INFORMATION.
  • 作成者: Nick
  • 所要時間: 2時間
  • 難易度: 難しい
If your AL2216W is having problems, it is very likely that it is a capacitor issue. Here are some signs of bad capacitors:
Note: While some issues may be corrected with a partial capacitor replacement, this is not recommended. Do all of the capacitors in one shot and you will not have to worry about the problem coming back a second time.
  • Power issues (This monitor has this issue)
  • Excessive transformer hum (This monitor has this issue)
  • Excessive inverter hum (This monitor has this issue)
  • Troublesome Auto adjustment (This monitor has this issue)
  • Backlight problems
  • Power problems
  • Video issues (Examples: Unstable image, Image drops when connected to a computer, does not play nice on higher resolutions, random image drops)
  • Random power issues that may only resolve if the monitor is physically unplugged.
Original capacitor values (Only use these if you do not want to install better caps then the monitor came with)
  • 25V 1000uF (x2)
  • 10V 1000uF (x1)
  • 25V 220uF (x2)
  • 16V 2200uF (Used on the inverter side of older power supplies)
ツール
関連部品
手順 1 Discharge the old capacitors  ¶
If you are uncertain about holding high voltage parts, follow all provided warnings and use common sense. A capacitor discharge tool is STRONGLY RECOMMENDED.
  • If you are uncertain about holding high voltage parts, follow all provided warnings and use common sense. A capacitor discharge tool is STRONGLY RECOMMENDED.
  • The filter capacitor will hold the most residual charge. Use caution around this capacitor!
  • Unplug the monitor and leave it unplugged for 24-48 hours. Wait 5-7 days if you intend to replace the filter capacitor.
手順 2 Remove the stand  ¶
This monitor never came with a hinge cap. If yours has one, snap it off from the marked points. Remove the stand from the monitor. The 4 screws that have to be removed are marked. The bottom screws should be removed first, but this can be done in any order.
  • This monitor never came with a hinge cap. If yours has one, snap it off from the marked points.
  • Remove the stand from the monitor. The 4 screws that have to be removed are marked. The bottom screws should be removed first, but this can be done in any order.
手順 3 Remove the back of the monitor  ¶
Remove 4 fine threaded screws from the back of the monitor. All of these screws are the same type and length. This screw is unique and only goes in one place as the thread is different. Set it aside separately from the other screws.
  • Remove 4 fine threaded screws from the back of the monitor. All of these screws are the same type and length.
  • This screw is unique and only goes in one place as the thread is different. Set it aside separately from the other screws.
手順 4 Unlatch the clips (Bottom)  ¶
If the monitor has never been serviced, additional force may be required. However, using too much will do more harm then good. A flathead screwdriver will damage the plastic.
  • If the monitor has never been serviced, additional force may be required. However, using too much will do more harm then good.
  • A flathead screwdriver will damage the plastic.
  • On the bottom of the monitor, there are four slots to open the monitor. To release these clips, use a Jimmy or flathead screwdriver.
手順 5 Unlatch the clips (Side)  ¶
If you are having trouble doing this, a pry tool can help. This issue is more likely to come up a monitor that has never been opened.
  • If you are having trouble doing this, a pry tool can help. This issue is more likely to come up a monitor that has never been opened.
  • With the monitor unclipped on the bottom, pull the sides of the monitor up. Do this slowly to avoid damaging the plastics and LCD.
手順 6 Remove the IEC socket screws  ¶
After these screws are removed, the power supply will be exposed.
  • After these screws are removed, the power supply will be exposed.
  • With the back of the monitor off, remove the 2 screws on the IEC power connector.
手順 7 Remove the video connection screws  ¶
If you do not have a nut driver on hand, needlenoose plyers can also be used.
  • If you do not have a nut driver on hand, needlenoose plyers can also be used.
  • Remove the 4 screw pins for the video cables from the monitor. Use a 5mm Nut bit/driver to remove the screw pins from the power supply shield.
手順 8 Disconnect the backlight cables  ¶
Disconnect the CCFL cables from the power supply board. Disconnect the CCFL cables from the power supply board.
  • Disconnect the CCFL cables from the power supply board.
手順 9 Disconnect the button board  ¶
The board does not interfere with disassembly and can be left alone. Disconnect the flat flex cable that goes to the control board.
  • The board does not interfere with disassembly and can be left alone.
  • Disconnect the flat flex cable that goes to the control board.
手順 10 Remove the power supply shield (Part 1)  ¶
Remove the 2 bottom screws that hold the power supply shield to the monitor. Remove the 2 bottom screws that hold the power supply shield to the monitor.
  • Remove the 2 bottom screws that hold the power supply shield to the monitor.
手順 11 Remove the power supply shield (Part 2)  ¶
On the right side of the monitor, remove the remaining screws holding the upper shield in place. Lift the lower plate up while removing the power supply shield to remove it from the monitor. Once this is done, you will have access to the power supply. Removal of the lower shield is not required. However, it will make disassembly easier. To remove it, unclip the plastic tabs on the LCD bezel.
  • On the right side of the monitor, remove the remaining screws holding the upper shield in place.
  • Lift the lower plate up while removing the power supply shield to remove it from the monitor. Once this is done, you will have access to the power supply.
  • Removal of the lower shield is not required. However, it will make disassembly easier. To remove it, unclip the plastic tabs on the LCD bezel.
手順 12 Remove the power supply  ¶
If you see bulged capacitors, treat the power supply as if the capacitors are holding a residual charge. In most cases, the filter capacitor is okay. It MUST be discharged if being replaced. In addition, the black screw (Blue marker) is a grounding screw and cannot be lost. Only lift the power supply board at a slight angle. Lifting it any more then this could result in pin or video processing board damage.
  • If you see bulged capacitors, treat the power supply as if the capacitors are holding a residual charge.
  • In most cases, the filter capacitor is okay. It MUST be discharged if being replaced. In addition, the black screw (Blue marker) is a grounding screw and cannot be lost.
  • Only lift the power supply board at a slight angle. Lifting it any more then this could result in pin or video processing board damage.
  • If you cannot find the original capacitors, the original parts can be safely substituted.
  • This capacitor is only used on older power supply boards. If your board has this capacitor, it should be repalced. However, it can be left alone if it looks okay.
  • With the power supply shield removed from the monitor, identify the power supply. Along with the listed capacitors, take note of any others you want to replace (Ex: Inverter coil).
  • Remove the 4 screws from the power supply. Once this is done, lift up the power supply at a slight angle to clear the chassis mounting holes.
手順 13 (Optional) Capacitor polarity marking  ¶
If the PCB is marked to avoid mis-installation, these marks will come off when exposed to solder flux.
  • If the PCB is marked to avoid mis-installation, these marks will come off when exposed to solder flux.
  • If you are unsure of the position of the capacitors, mark the polarity with a permanent marker. If the capacitors are installed incorrectly, they will explode when the monitor is powered on.
手順 14 Add flux to the capacitor leads  ¶
If you do not have flux on hand, solder can be used. The flux will be more difficult to clean if too much is used.
  • If you do not have flux on hand, solder can be used. The flux will be more difficult to clean if too much is used.
  • To prepare the board for capacitor replacement, put flux or solder on the existing capacitors. This will make removal easier.
手順 15 Remove the old capacitors  ¶
If you do not have a Helping Hands, be careful not to touch your soldering iron. Try holding the board at an angle to make this easier. While it may be possible to do a partial capacitor replacement, the remaining capacitors will also fail - do it once and do it correctly. Refer to this guide for soldering tips: はんだ付けとはんだ除去の作業ガイド. Move in a workspace with ventilation or use a fume extractor. Once in an appropriate workspace, desolder the old capacitors. Heat one leg up and remove the capacitor. Do this for both legs.
  • If you do not have a Helping Hands, be careful not to touch your soldering iron. Try holding the board at an angle to make this easier.
  • While it may be possible to do a partial capacitor replacement, the remaining capacitors will also fail - do it once and do it correctly. Refer to this guide for soldering tips: はんだ付けとはんだ除去の作業ガイド.
  • Move in a workspace with ventilation or use a fume extractor. Once in an appropriate workspace, desolder the old capacitors. Heat one leg up and remove the capacitor. Do this for both legs.
  • After removing the capacitors, clean up the old solder. To do this, take a desoldering braid and clean up the solder from the pads. The desoldering braid must be lifted up with your soldering iron.
手順 16 Installing brand new capacitors  ¶
Check the capacitor polarity before soldering the new capacitors in. If they are installed incorrectly, they will explode!
  • Check the capacitor polarity before soldering the new capacitors in. If they are installed incorrectly, they will explode!
  • Install new capacitors. Put the corresponding capacitor you are installing in the correct hole. Bend the leads to keep the capacitor from coming out.
手順 17 Solder the new capacitors in  ¶
Once the polarity is verified, solder the capacitors in. Once soldered, cut the excess lead. Do this for all of the capacitors. Once the polarity is verified, solder the capacitors in. Once soldered, cut the excess lead. Do this for all of the capacitors. Once the polarity is verified, solder the capacitors in. Once soldered, cut the excess lead. Do this for all of the capacitors.
  • Once the polarity is verified, solder the capacitors in. Once soldered, cut the excess lead. Do this for all of the capacitors.
手順 18 Clean the flux off of the board  ¶
After verifying there are no cold solder joints, clean the board. This can be cleaned with 91%+ Isopropyl or Denatured alcohol.
  • After verifying there are no cold solder joints, clean the board. This can be cleaned with 91%+ Isopropyl or Denatured alcohol.
手順 19 Test the monitor  ¶
Put the monitor back together and test it by giving it a signal. If your monitor works, an image should be produced.
  • Put the monitor back together and test it by giving it a signal. If your monitor works, an image should be produced.
