メインコンテンツにスキップ
ヘルプ
Samsung Sway Motherboard Replacement
高画質の画像が必要
高画質の画像が必要
よりよい画像があればこのガイドが改善されます。よければ新しい写真を撮影し、編集し、アップロードしてお手伝いください。
より良い紹介部分
より良い紹介部分
この紹介部分を完成し編集することでこのガイドを改良する
This guide will show you how to replace the motherboard. It will also show you how to open up the phone to get to the internal componets of the phone.
This will help you replace the motherboard of the phone to fix a hardware problem.
手順 1 Motherboard  ¶
Using your thumb(s) slide the cover up to remove Remove the battery by using your finger either in the upper left or right corner Remove the battery by using your finger either in the upper left or right corner
手順 1 Motherboard  ¶
  • Using your thumb(s) slide the cover up to remove
  • Remove the battery by using your finger either in the upper left or right corner
手順 2  ¶
Unscrew the four corner .4cm Phillips head screws.
手順 2  ¶
  • Unscrew the four corner .4cm Phillips head screws.
手順 3  ¶
Using a pair of tweezers gently insert them under the Samsung logo on the bottom of the phone.
手順 3  ¶
  • Using a pair of tweezers gently insert them under the Samsung logo on the bottom of the phone.
手順 4  ¶
Unscrew the two .4 cm Phillips head screws from under the Samsung logo
手順 4  ¶
  • Unscrew the two .4 cm Phillips head screws from under the Samsung logo
手順 5  ¶
Using the plastic opening tool gently insert it into the seam and work it around till the cover comes off.  Being careful of the side buttons that pop off.
手順 5  ¶
  • Using the plastic opening tool gently insert it into the seam and work it around till the cover comes off. Being careful of the side buttons that pop off.
手順 6  ¶
Grasp the sides of the motherboard and gently rock back and forth .  This is due to the sticky tape that is on the battery
手順 6  ¶
  • Grasp the sides of the motherboard and gently rock back and forth . This is due to the sticky tape that is on the battery
手順 7  ¶
Disconnect the black serial cable from the mother board.
手順 7  ¶
  • Disconnect the black serial cable from the mother board.
手順 8  ¶
Gently pull of the antenna sticker tape.
手順 8  ¶
  • Gently pull of the antenna sticker tape.
