メインコンテンツにスキップ
ヘルプ
Démontage de super-vario 40 display braille
メンバーによる寄稿ガイド
メンバーによる寄稿ガイド
私たちのコミュニティーの素晴らしいメンバーがこのガイドを作成しました。これはiFixitスタッフによって管理されていません。
vous allez accomplir le démontage complet de super vario 40 Baum
  • 作成者: Sisyphe
  • 所要時間: 15分
  • 難易度: 普通
Use this guide to assist with general disassembly or troubleshooting of your braille display.
手順 1 Démontage de super-vario 40 display braille  ¶
Remove the four bottom screws with a Phillips #00 screwdriver. Remove the four bottom screws with a Phillips #00 screwdriver.
  • Remove the four bottom screws with a Phillips #00 screwdriver.
手順 2  ¶
Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset. Remove the plastic cover, paper and chipset.
手順 2  ¶
  • Remove the plastic cover, paper and chipset.
手順 3  ¶
Remove the two screws with a Phillips #00 screwdriver on the logic board. take out the main circuit like show in the picture take out the main circuit like show in the picture
手順 3  ¶
  • Remove the two screws with a Phillips #00 screwdriver on the logic board.
  • take out the main circuit like show in the picture
手順 4  ¶
Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver. Remove the four screws with a Phillips #00 screwdriver.
手順 4  ¶
  • Remove the four screws with a Phillips #00 screwdriver.
手順 5  ¶
Remove the connector delicately. Remove the connector delicately. Remove the connector delicately.
手順 5  ¶
  • Remove the connector delicately.
手順 6  ¶
when you put it back together make sure mechanical cells are connected correctly when you put it back together make sure mechanical cells are connected correctly
手順 6  ¶
  • when you put it back together make sure mechanical cells are connected correctly
