メインコンテンツにスキップ
ヘルプ
技術: Repairing Oster 6344 Toaster Lever
多くの画像が必要
多くの画像が必要
幾つかの画像があればこのガイドの手順がより明確になるでしょう。
This guide will help you master the art of fixing toaster levers, with optional cleanup as well!
  • 作成者: Daniel
  • 難易度: 簡単
This is how to repair the lever on your Oster Toaster
手順 1 Repairing Oster 6344 Toaster Lever  ¶
Assure the toaster is unplugged. Assure the toaster is unplugged. Assure the toaster is unplugged.
  • Assure the toaster is unplugged.
手順 2  ¶
Look down into the bread slots and assure that the metal tongues are not bent or crooked. Look down into the bread slots and assure that the metal tongues are not bent or crooked.
手順 2  ¶
  • Look down into the bread slots and assure that the metal tongues are not bent or crooked.
手順 3  ¶
画像がありません
手順 3  ¶
  • If the metal tongues are bent use the pliers to straighten them.
手順 4  ¶
画像がありません
手順 4  ¶
  • Plug your toaster back in and test it to see if the lever stays down.
手順 5  ¶
(Optional): To clean the toaster, make sure it is unplugged, empty the crumb tray and then clean out all visible residue.
手順 5  ¶
  • (Optional): To clean the toaster, make sure it is unplugged, empty the crumb tray and then clean out all visible residue.
  • Note: Compressed air, wooden skewers, and slightly damp, lint free cloths are most helpful when cleaning your toaster.
  • Be sure that the toaster is completely dry from cleaning before you reassemble it.
