メインコンテンツにスキップ
ヘルプ
iMac Intel 27" EMC 2546 Hard Drive
必要条件のみ
必要条件のみ
このガイドは他のガイドにとって唯一の必要条件であることに注意してください。
prerequisite guide, hard drive removal
手順 1 Hard Drive  ¶
Pull straight up on the SATA data/power cable to disconnect it from the drive. Pull straight up on the SATA data/power cable to disconnect it from the drive.
手順 1 Hard Drive  ¶
  • Pull straight up on the SATA data/power cable to disconnect it from the drive.
手順 2  ¶
Remove two 7.3 mm T10 screws securing the left hard drive bracket to the rear case.
手順 2  ¶
  • Remove two 7.3 mm T10 screws securing the left hard drive bracket to the rear case.
手順 3  ¶
Grab the hard drive and left hard drive bracket together. Tilt the left side up away from the rear case, and slide the assembly to the left. Remove the hard drive and left hard drive bracket from the iMac.
手順 3  ¶
  • Grab the hard drive and left hard drive bracket together.
  • Tilt the left side up away from the rear case, and slide the assembly to the left.
  • Remove the hard drive and left hard drive bracket from the iMac.
手順 4  ¶
Remove the left hard drive bracket. Remove the left hard drive bracket.
手順 4  ¶
  • Remove the left hard drive bracket.
