メインコンテンツにスキップ
ヘルプ
Medion Akoya MD 98560 Heat Sink Replacement
メンバーによる寄稿ガイド
メンバーによる寄稿ガイド
私たちのコミュニティーの素晴らしいメンバーがこのガイドを作成しました。これはiFixitスタッフによって管理されていません。
These laptops found in ALDI stores are some of the cheapest around on the market, and this one is a trick to customers. It specifies high end specs and graphics but when trying to actually achieve these, the CPU overheats and crashes.
  • 作成者: Ikfixda
  • 難易度: 普通
We will be disassembling the laptop down to the heatsink and CPU, to apply some thermal paste with a higher grade of conductivity.
手順 1 Heat Sink  ¶
Remove the battery by sliding both sliders to the left.
手順 1 Heat Sink  ¶
  • Remove the battery by sliding both sliders to the left.
  • Hold the left slider as you slide the battery away from you.
手順 2  ¶
Press and hold the power button for 10 - 15 seconds, to release any excess power from the laptop.
手順 2  ¶
  • Press and hold the power button for 10 - 15 seconds, to release any excess power from the laptop.
手順 3  ¶
After removing the battery, undo the single screw holding the RAM compartment lid.
手順 3  ¶
  • After removing the battery, undo the single screw holding the RAM compartment lid.
  • Gently pop out the lid with a few clicks.
手順 4  ¶
Undo the white and black cable, and the screw.
手順 4  ¶
  • Undo the white and black cable, and the screw.
  • Lift the wifi board up and away from you.
手順 5  ¶
Pry the metal clips holding the RAM units outward which will make the uint pop upwards. Slide the unit out, towards you.
手順 5  ¶
  • Pry the metal clips holding the RAM units outward which will make the uint pop upwards.
  • Slide the unit out, towards you.
手順 6  ¶
Undo the single screw holding the hard drive lid.
手順 6  ¶
  • Undo the single screw holding the hard drive lid.
手順 7  ¶
Undo the single screw holding the hard drive.
手順 7  ¶
  • Undo the single screw holding the hard drive.
手順 8  ¶
Use the black tab to slide the hard drive backwards. Pry the hard drive up, on the far side and it slides out.
手順 8  ¶
  • Use the black tab to slide the hard drive backwards.
  • Pry the hard drive up, on the far side and it slides out.
  • Be careful when prying the hard drive out of the case, you might drop it and damage it.
手順 9  ¶
Push the 4 black tabs located at the top of the keyboard, under the case. Push the 4 black tabs located at the top of the keyboard, under the case.
手順 9  ¶
  • Push the 4 black tabs located at the top of the keyboard, under the case.
手順 10  ¶
Be careful when removing the keyboard from the case, it is still attached at the bottom. Pry the black tab backwards, to remove the cable.
手順 10  ¶
  • Be careful when removing the keyboard from the case, it is still attached at the bottom.
  • Pry the black tab backwards, to remove the cable.
手順 11  ¶
On the bottom of the case there are 2 sliders, use these to release the optical drive. On the bottom of the case there are 2 sliders, use these to release the optical drive.
手順 11  ¶
  • On the bottom of the case there are 2 sliders, use these to release the optical drive.
手順 12  ¶
Undo the 11 screws holding the bottom of the case.
手順 12  ¶
  • Undo the 11 screws holding the bottom of the case.
手順 13  ¶
Remove the 2 cables, revealed by removing the keyboard. The cables mentioning "MB" can only be removed after opening the case. Remove the 2 cables, revealed by removing the keyboard. The cables mentioning "MB" can only be removed after opening the case.
手順 13  ¶
  • Remove the 2 cables, revealed by removing the keyboard. The cables mentioning "MB" can only be removed after opening the case.
手順 14  ¶
Pry open the case using something soft, preferably your hands or a spudger.
手順 14  ¶
  • Pry open the case using something soft, preferably your hands or a spudger.
手順 15  ¶
When the case is completely lose it will still be attached by the "MB" cables. Remove those before completely removing the case.
手順 15  ¶
  • When the case is completely lose it will still be attached by the "MB" cables. Remove those before completely removing the case.
手順 16  ¶
Undo the single screw holding the motherboard.
手順 16  ¶
  • Undo the single screw holding the motherboard.
  • Undo the 4 cables highlighted in blue.
手順 17  ¶
Also remove the black and white wifi cable from under the motherboard.
手順 17  ¶
  • Also remove the black and white wifi cable from under the motherboard.
手順 18  ¶
Lift the motherboard out of its socket. The bottom left may get stuck a bit. Don't force the USB sockets.
手順 18  ¶
  • Lift the motherboard out of its socket. The bottom left may get stuck a bit. Don't force the USB sockets.
手順 19  ¶
On the flipside of the motherboard is the CPU covered by the heatsink. Before removing the heatsink, remove the fan cable looping over the heatsink.
手順 19  ¶
  • On the flipside of the motherboard is the CPU covered by the heatsink.
  • Before removing the heatsink, remove the fan cable looping over the heatsink.
  • Remove the 6 screws, holding the heatsink.
手順 20  ¶
First you will need a card to scrape off the old paste. Keep a coffee filter ready to clean the card.
手順 20  ¶
  • First you will need a card to scrape off the old paste. Keep a coffee filter ready to clean the card.
  • Both the heatsink and CPU's must be totally cleaned of any remaining grease.
  • The triangular part on the heatsink leads to the graphics card.
手順 21  ¶
Be very thorough, any remaining grease may render your new layer of paste useless.
手順 21  ¶
  • Be very thorough, any remaining grease may render your new layer of paste useless.
  • The top cores are the CPU, still not cleaned.
  • The bottom core is the newly cleaned video card CPU.
手順 22  ¶
Use alcohol or a oil-free degreaser and coffee filters or a lint-free cloth. Use alcohol or a oil-free degreaser and coffee filters or a lint-free cloth.
手順 22  ¶
  • Use alcohol or a oil-free degreaser and coffee filters or a lint-free cloth.
手順 23  ¶
画像がありません
手順 23  ¶
  • Apply the paste on the CPU's very carefully, you don't want certain thermal pastes on electrical circuits.
  • Your paste needs to be distributed evenly on the whole metal cap of the CPU.
  • Reverse engineer this guide to put the laptop back together.
  • Let the paste settle in by letting the computer run for a few consecutive hours.
  • Run a temperature monitor software to check if your application has been effective or not. After a day or two, you may want to stress-test it by running some high end application all together and monitor the temperature.
