メインコンテンツにスキップ
ヘルプ
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement
  • 作成者: Walter Galan
  • 所要時間: 1 - 5 分
  • 難易度: 簡単
Remove the lower case to access most of your MacBook Pro's internals.
手順 1 Lower Case  ¶
Remove the following ten screws securing the lower case to the upper case:
手順 1 Lower Case  ¶
  • Seven 3 mm Phillips screws.
手順 2  ¶
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
手順 2  ¶
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
