メインコンテンツにスキップ
ヘルプ
iBook G3 14" Modem Replacement
  • 作成者: iRobot
  • 難易度: 難しい
56k internal modem, standard on all models.
セクション
ファイル
手順 1 Modem  ¶
Remove the single strip of tape running across the modem.
手順 1 Modem  ¶
  • Remove the single strip of tape running across the modem.
  • Remove the single Phillips screw securing the display data cable to the metal framework.
手順 2  ¶
Move the display data cable in order to access and remove a single Phillips screw from the front left corner of the modem.
手順 2  ¶
  • Move the display data cable in order to access and remove a single Phillips screw from the front left corner of the modem.
  • Remove the single Phillips screw remaining at the upper, right corner of the modem.
手順 3  ¶
Lift the modem from the logic board on the right side, being careful not to strain the display data cable.
手順 3  ¶
  • Lift the modem from the logic board on the right side, being careful not to strain the display data cable.
  • Disconnect the modem cable from the upper, left corner of the modem.
手順 4  ¶
Slide the modem out of the computer, being careful to avoid catching the black plastic shielding on the surrounding cables.
手順 4  ¶
  • Slide the modem out of the computer, being careful to avoid catching the black plastic shielding on the surrounding cables.
