メインコンテンツにスキップ
ヘルプ
iHome IH11 Main Motherboard Replacement
アクションショット
アクションショット
アクションヒーローになりましょう!このガイドはある特定の動作をどのように行なうのか、より詳細な画像が必要です。
より良い紹介部分
より良い紹介部分
この紹介部分を完成し編集することでこのガイドを改良する
Dissasemble your iHome to remove and install the main motherboard.
This guide will show how to install a new mother board in the iHome. For help troubleshooting click the link to our troubleshooting page iHome IH11 Troubleshooting.
手順 1 Outer Case  ¶
Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
手順 1 Outer Case  ¶
  • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
  • Remove the translucent bottom case.
手順 2  ¶
Remove the two Phillips #1 9.0mm screws on the back of the iHome. Repeat the previous step for the two 9.0mm screws on the bottom.
手順 2  ¶
  • Remove the two Phillips #1 9.0mm screws on the back of the iHome.
  • Repeat the previous step for the two 9.0mm screws on the bottom.
  • Carefully slide the back cover off. There are wires connected to the back cover.
手順 3  ¶
Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
手順 3  ¶
  • Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
  • Pull the bracket out.
手順 4  ¶
Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver. Slide the motherboard gently out.
手順 4  ¶
  • Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver.
  • Slide the motherboard gently out.
手順 5  ¶
Solder each wire to corresponding input on the motherboard.
手順 5  ¶
  • Solder each wire to corresponding input on the motherboard.
