メインコンテンツにスキップ
ヘルプ
Palm Treo Pro Motherboard Replacement
不明瞭なテキスト
不明瞭なテキスト
このガイドのテキストの数カ所が混乱し、重複しトピックから外れています。編集してより明確にしてください!
高画質の画像が必要
高画質の画像が必要
よりよい画像があればこのガイドが改善されます。よければ新しい写真を撮影し、編集し、アップロードしてお手伝いください。
This guide will walk you step-by-step through the process to replace a faulty motherboard with a new one.
  • 作成者: Nadia Carroll
  • 所要時間: 15 - 20 分
  • 難易度: 普通
The following 11 steps will help you replace a faulty motherboard with a new one.
ツール (続く)
関連部品
手順 1 Motherboard  ¶
Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone. Be careful not to misplace these screws as they are very small and will be important during reassembly. If the screws are stripped a flat head screw driver may be necessary.
手順 1 Motherboard  ¶
  • Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
  • Be careful not to misplace these screws as they are very small and will be important during reassembly.
  • If the screws are stripped a flat head screw driver may be necessary.
手順 2  ¶
Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera. Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera. Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
手順 2  ¶
  • Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
手順 3  ¶
Remove the main plastic body Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone. The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
手順 3  ¶
  • Remove the main plastic body
  • Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone.
  • The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
手順 4  ¶
Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone. Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard. Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
手順 4  ¶
  • Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone.
  • Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
手順 5  ¶
Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables. Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
手順 5  ¶
  • Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
手順 6  ¶
There are two ribbon cables under the yellow tape. Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable. To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
手順 6  ¶
  • There are two ribbon cables under the yellow tape.
  • Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable.
  • To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
手順 7  ¶
Use a plastic opening tool to lift the motherboard up and out of the phone case There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone It can easily be disconnected with your fingers
手順 7  ¶
  • Use a plastic opening tool to lift the motherboard up and out of the phone case
  • There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
  • It can easily be disconnected with your fingers
  • Note: During this process the mute and power buttons may fall out of the phone. Do not panic this is completely normal. Set them aside in a safe place until reassembly.
  • The motherboard has now been completely removed
