メインコンテンツにスキップ
ヘルプ
Ericsson A2628 Teardown
分解
分解
分解とはdeviceの内部構造を見て確認することです。解体の手引きとして使う事はできません。
高画質の画像が必要
高画質の画像が必要
よりよい画像があればこのガイドが改善されます。よければ新しい写真を撮影し、編集し、アップロードしてお手伝いください。
メンバーによる寄稿ガイド
メンバーによる寄稿ガイド
私たちのコミュニティーの素晴らしいメンバーがこのガイドを作成しました。これはiFixitスタッフによって管理されていません。
より良い紹介部分
より良い紹介部分
この紹介部分を完成し編集することでこのガイドを改良する
手順 1 Ericsson A2628 Teardown  ¶
We'll start by flipping the phone with its back towards us and pushing on the top of the battery cover, then pulling down the cover as shown. We'll start by flipping the phone with its back towards us and pushing on the top of the battery cover, then pulling down the cover as shown. We'll start by flipping the phone with its back towards us and pushing on the top of the battery cover, then pulling down the cover as shown.
  • We'll start by flipping the phone with its back towards us and pushing on the top of the battery cover, then pulling down the cover as shown.
手順 2  ¶
The battery is connected to the board by a cable ending in a white connector on the board (shown  in picture 1). We'll need to pull that out. The battery is then lifted by its lower half and, when reaching about 50-60 degrees, allows itself to be pulled out, revealing the phone's SIM card slot and info. The battery is then lifted by its lower half and, when reaching about 50-60 degrees, allows itself to be pulled out, revealing the phone's SIM card slot and info.
手順 2  ¶
  • The battery is connected to the board by a cable ending in a white connector on the board (shown in picture 1). We'll need to pull that out.
  • The battery is then lifted by its lower half and, when reaching about 50-60 degrees, allows itself to be pulled out, revealing the phone's SIM card slot and info.
手順 3  ¶
Romania version. Oh wow, they made holographic logos for this series. Romania version. Oh wow, they made holographic logos for this series.
手順 3  ¶
  • Romania version. Oh wow, they made holographic logos for this series.
手順 4  ¶
To eject the front cover, pull down on the blue switch (as shown in picture one) and then, while holding the switch down, gently pull from the front of the cover as shown in picture two. Front cover off, we can now see the microphone. But it's not reachable from here, there's a transparent plastic body over it. Front cover off, we can now see the microphone. But it's not reachable from here, there's a transparent plastic body over it.
手順 4  ¶
  • To eject the front cover, pull down on the blue switch (as shown in picture one) and then, while holding the switch down, gently pull from the front of the cover as shown in picture two.
  • Front cover off, we can now see the microphone. But it's not reachable from here, there's a transparent plastic body over it.
手順 5  ¶
Now for the top cover. Unscrew the two screws holding it to the board (shown in picture one, already unscrewed) The board is held onto the board by an extra 3 clips. Unclip the bottom two (position shown in picture 2) and then pull the board out by holding onto the top part and the board and pulling one from the other (shown in picture 3) The board is held onto the board by an extra 3 clips. Unclip the bottom two (position shown in picture 2) and then pull the board out by holding onto the top part and the board and pulling one from the other (shown in picture 3)
手順 5  ¶
  • Now for the top cover. Unscrew the two screws holding it to the board (shown in picture one, already unscrewed)
  • The board is held onto the board by an extra 3 clips. Unclip the bottom two (position shown in picture 2) and then pull the board out by holding onto the top part and the board and pulling one from the other (shown in picture 3)
手順 6  ¶
The top cover is now removed. The antenna and antenna connectors are shown in picture one. Time to remove the metal body off the board. You should easily notice the presence of six T6 screws that need to be removed. Get on it. Notice that two of the screws are of different dimensions and colors when compared to the other four(picture three). Keep that in mind when re-assembling.
手順 6  ¶
  • The top cover is now removed. The antenna and antenna connectors are shown in picture one.
  • Time to remove the metal body off the board. You should easily notice the presence of six T6 screws that need to be removed. Get on it.
  • Notice that two of the screws are of different dimensions and colors when compared to the other four(picture three). Keep that in mind when re-assembling.
手順 7  ¶
The body should go right off without those screws to hold it. Careful, the Charging/data port is not soldiered to the board and may fall out of place. 3004CR1C Q8753 MPJ 01041 T035 403 05/1 22100
手順 7  ¶
  • The body should go right off without those screws to hold it. Careful, the Charging/data port is not soldiered to the board and may fall out of place.
  • 3004CR1C Q8753 MPJ 01041
  • T035 403 05/1 22100
  • ERICSSON 101102/5CR2B 004839AD
  • AU051 PBM 990 28/11 ROP101303011 P1A A9924
  • 1120/8C 0BAH05T RTA
  • Removing the front part from the board, we find the keyboard membrane(here shown with a few quick fixes in picture three)
手順 8  ¶
Here's  some macros of the motherboard. Also there's the bottom connector. it slides right out, so no worries. Also there's the bottom connector. it slides right out, so no worries.
手順 8  ¶
  • Here's some macros of the motherboard.
  • Also there's the bottom connector. it slides right out, so no worries.
手順 9  ¶
The membrane comes off easily  from the transparent part, but be careful of the top part where it spirals right next to the speaker. That part comes out harder. 00 H MUT03E N/R STAR
手順 9  ¶
  • The membrane comes off easily from the transparent part, but be careful of the top part where it spirals right next to the speaker. That part comes out harder.
  • 00 H MUT03E N/R STAR
  • Microphone
  • Speaker
  • The screen will now come out if it's pushed from the outside.
手順 10  ¶
And now for a summary of all the parts. And now for a summary of all the parts.
手順 10  ¶
  • And now for a summary of all the parts.
