メインコンテンツにスキップ
ヘルプ
Canon PowerShot SD 600 Rear Control Board Replacement
This guide is about how to remove the orange rear control board. Be aware that this board is connected to the speaker, top controls and the optical view finder and these will all need to be removed/replaced as a unit.
  • 作成者: Greg H
  • 難易度: 普通
Before completing this guide, the camera exterior, top external controls, and rear screen of the camera should be removed for easy access to cables.
手順 1 Rear Control Board  ¶
First it is necessary to remove the ribbon cable connecting the control board to the [green] rear accessory board  on the camera.
  • First it is necessary to remove the ribbon cable connecting the control board to the [green] rear accessory board on the camera.
  • This is done by unsnapping the jawbone connector and gently pulling the cable out with tweezers or the spudger.
手順 2  ¶
Using the spudger, gently push up the board from the pins underneath it. Follow the board up and around the camera, gently unseating the board and cables. The speaker will still be connected to the board via two small power wires. Use the tweezers to pull and unplug the power connector from the main rear accessory board.
手順 2  ¶
  • Using the spudger, gently push up the board from the pins underneath it.
  • Follow the board up and around the camera, gently unseating the board and cables.
  • The speaker will still be connected to the board via two small power wires. Use the tweezers to pull and unplug the power connector from the main rear accessory board.
  • For best results, grip the tweezers as close to the plug as possible.
手順 3  ¶
Grip the top control board with the tweezers and gently pull up to unseat it from the placement pins it sits on. Be aware that the optical viewfinder is connected to the top control board and should come out with it. If need be, use the spudger to gently pry out the optical viewfinder.
手順 3  ¶
  • Grip the top control board with the tweezers and gently pull up to unseat it from the placement pins it sits on.
  • Be aware that the optical viewfinder is connected to the top control board and should come out with it.
  • If need be, use the spudger to gently pry out the optical viewfinder.
  • Note that the orientation of the camera has been changed in this step in order to properly show the top face of the camera.
手順 4  ¶
The rear control board should now be completely separate from the camera.
手順 4  ¶
  • The rear control board should now be completely separate from the camera.
