メインコンテンツにスキップ
ヘルプ
Dell Latitude D630 RAM (Slot B) Replacement
This guide will help you install RAM in the first slot, located directly beneath the laptop.
  • 作成者: Jon Amireh
  • 所要時間: 5分
  • 難易度: とても簡単
Introduction
Ram is your laptops temporary memory and can be replaced if damaged or you can upgrade it. This will help run more programs or make the ones you run faster and more efficient.
This Guide Will Teach You
  1. Where the ram is located
  2. How to remove safely
  3. Tools needed to complete the replacement
セクション
ツール
手順 1 RAM (Slot B)  ¶
Locate and unscrew the captive screw indicated in the picture on the left to detach the panel.
手順 1 RAM (Slot B)  ¶
  • Locate and unscrew the captive screw indicated in the picture on the left to detach the panel.
手順 2  ¶
Use your fingers to push out the latches holding the RAM in place.
手順 2  ¶
  • Use your fingers to push out the latches holding the RAM in place.
  • The RAM should now sit up at an angle so you can safely remove it.
