ヘルプ
HP Mini 311 Keyboard Replacement
This installation guide will provide directions for the replacement of a keyboard on an HP Mini 311.
If you have experienced a malfunction with your keys or overall keyboard, you should change the entire keyboard on your HP Mini 311.
セクション
ツール
手順 1 Keyboard  ¶
Unscrew the four Phillip 00 5.6 mm screws located around the wireless card and RAM.
手順 1 Keyboard  ¶
  • Unscrew the four Phillip 00 5.6 mm screws located around the wireless card and RAM.
手順 2  ¶
Open the laptop so that the screen and front of the keyboard are both facing the ground.
手順 2  ¶
  • Open the laptop so that the screen and front of the keyboard are both facing the ground.
  • Push on the opening on the back side of the device until the keyboard partially pops out.
  • This opening is located where the original hard drive was set.
手順 3  ¶
Flip the device around and orient it so that the screen and keyboard are facing you. Starting at the right side, work your way towards the left end and remove the keyboard by unhinging the latches attaching it to the base of the device. The right side of the keyboard should be unattached.
手順 3  ¶
  • Flip the device around and orient it so that the screen and keyboard are facing you.
  • Starting at the right side, work your way towards the left end and remove the keyboard by unhinging the latches attaching it to the base of the device.
  • The right side of the keyboard should be unattached.
  • Be gentle and patient. You don't want to pull the entire keyboard at once, but rather pull by sections.
手順 4  ¶
Carefully pull the ribbon cable connecting the keyboard and the laptop to remove from the device. Carefully pull the ribbon cable connecting the keyboard and the laptop to remove from the device. Carefully pull the ribbon cable connecting the keyboard and the laptop to remove from the device.
手順 4  ¶
  • Carefully pull the ribbon cable connecting the keyboard and the laptop to remove from the device.
