ヘルプ
技術: Adjust the Action (String Height) on Ibanez SR405QM
不明瞭なテキスト
不明瞭なテキスト
このガイドのテキストの数カ所が混乱し、重複しトピックから外れています。編集してより明確にしてください!
高画質の画像が必要
高画質の画像が必要
よりよい画像があればこのガイドが改善されます。よければ新しい写真を撮影し、編集し、アップロードしてお手伝いください。
間違いの指摘
間違いの指摘
このガイドは最適な校正が必要です。校正の注釈を付けたり訂正することにご協力ください。
In this guide you will learn how to change the height of your strings in order to play easier, or stop the strings from hitting the fret board when plucked.
The height of your strings greatly effects playing. If the strings are too high, it may be difficult to finger the notes with your left hand, and certain techniques like fingerstyle (tapping) maybe be overly difficult. Conversely, if the strings are too low, they may hit the fret board producing distasteful sounds. Thus a happy medium must be found for each string.
Personally, I have my thicker lower strings much higher so I can play with gusto, while my high strings are by the tip of the fret board for ease when finger tapping. Everyone will have their own personal taste when it comes to string height.
ツール
手順 1 Adjust the Action (String Height) on Ibanez SR405QM  ¶
Take note of the distance from both the fret board and pick ups. Take note of the distance from both the fret board and pick ups.
  • Take note of the distance from both the fret board and pick ups.
手順 2  ¶
Check to see when the bass is played, does it feel difficult to play high notes on your low strings, or do any notes produce a metallic sound when played.
手順 2  ¶
  • Check to see when the bass is played, does it feel difficult to play high notes on your low strings, or do any notes produce a metallic sound when played.
  • Note: When this string is plucked it vibrates against the fret board causing an unpleasant metallic sound.
手順 3  ¶
Locate upon the bridge the hex screw that corresponds with the string which is either too high or too low.
手順 3  ¶
  • Locate upon the bridge the hex screw that corresponds with the string which is either too high or too low.
  • Note: In this guide we will be making the B string higher. So we will adjust the B strings hex screw.
手順 4  ¶
Using the hex screw, turn clockwise to raise the string and counter clockwise to lower the string. While trying to raise the string: Pluck the string after each quarter turn to determine whether the metallic sound has gone.
手順 4  ¶
  • Using the hex screw, turn clockwise to raise the string and counter clockwise to lower the string.
  • While trying to raise the string: Pluck the string after each quarter turn to determine whether the metallic sound has gone.
  • While trying to lower a string: Pluck the string after each quarter turn to see if a metallic vibration can be felt.
  • Adjust the string height to your preference.
