ヘルプ
Nintendo Wii U Console Outer Case Replacement
おすすめの学生による修理ガイド
おすすめの学生による修理ガイド
このガイドは当社の素晴らしい学生たちによって作成中であり、iFixitスタッフによってとりわけ素晴らしいガイドであると注目されています。
Installing the Wii U Outer Case.
  • 作成者: Kim Arre
  • 所要時間: 20分
  • 難易度: 普通
Use this guide to remove the outer case of the Nintendo Wii U and gain access to the DVD drive.
手順 1 Console Outer Case  ¶
With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
  • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
  • Three 5.1mm Phillips #000 screws
  • Two 6.1mm Tri-wing Y0 screws
  • One 13.2mm Tri-wing Y1 screw
手順 2  ¶
Rotate the console 180 degrees so that the exhaust vents are facing you.
手順 2  ¶
  • Rotate the console 180 degrees so that the exhaust vents are facing you.
  • Remove the two 7.1mm Phillips #00 screws.
手順 3  ¶
On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it. On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
手順 3  ¶
  • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
手順 4  ¶
On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
手順 4  ¶
  • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
手順 5  ¶
On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover.
手順 5  ¶
  • On the back of the console, lift up and release the main top cover.
