メインコンテンツにスキップ
ヘルプ
Canon PowerShot A460 Motherboard Replacement
多くの画像が必要
多くの画像が必要
幾つかの画像があればこのガイドの手順がより明確になるでしょう。
間違いの指摘
間違いの指摘
このガイドは最適な校正が必要です。校正の注釈を付けたり訂正することにご協力ください。
アクションショット
アクションショット
アクションヒーローになりましょう!このガイドはある特定の動作をどのように行なうのか、より詳細な画像が必要です。
ステップトリマー
ステップトリマー
このガイドには不要な手順があります。より明瞭にするためにこれらの部分を取り除きます。
This guide will show how to remove the motherboard of the camera.
This guide will involve the removal of various screws, as well as detaching the two gold ribbons connecting the motherboard to the camera.
セクション
手順 1 Motherboard  ¶
Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
手順 1 Motherboard  ¶
  • Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
手順 2  ¶
Remove the 4mm Phillips #00 screw at the bottom of the black piece. Detach the black piece that the screws previously held in place.
手順 2  ¶
  • Remove the 4mm Phillips #00 screw at the bottom of the black piece.
  • Detach the black piece that the screws previously held in place.
手順 3  ¶
Remove the 5mm Phillips #00 screw in the middle of the motherboard.
手順 3  ¶
  • Remove the 5mm Phillips #00 screw in the middle of the motherboard.
手順 4  ¶
Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
手順 4  ¶
  • Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
手順 5  ¶
Remove the 5mm Phillips #00 screw that is located on the top of camera.
手順 5  ¶
  • Remove the 5mm Phillips #00 screw that is located on the top of camera.
手順 6  ¶
Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
手順 6  ¶
  • Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
  • Be careful not to damage the multiple adjacent orange ribbons.
手順 7  ¶
Remove the 5mm Phillips #00 screw near the bottom left of the motherboard.
手順 7  ¶
  • Remove the 5mm Phillips #00 screw near the bottom left of the motherboard.
手順 8  ¶
Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place. Once unlocked, slide out the ribbon.
手順 8  ¶
  • Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
  • Once unlocked, slide out the ribbon.
手順 9  ¶
Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
手順 9  ¶
  • Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
手順 10  ¶
All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
手順 10  ¶
  • All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
