メインコンテンツにスキップ
ヘルプ
Motorola Moto E4 Plus Power and Volume Buttons Replacement
This guide shows how to remove the power and volume buttons in the Motorola Moto E4 Plus (XT1771).
Use this guide to remove the power and volume buttons in the Motorola Moto E4 Plus (XT1771).
Before disassembling your phone, discharge the battery below 25%. If your battery is swollen, do not heat your phone. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
手順 1 Power & Volume Button  ¶
Use the edge of a spudger to open the lever of the ZIF connector. Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector. Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
  • Use the edge of a spudger to open the lever of the ZIF connector.
  • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
手順 2  ¶
Use a pair of tweezers to gently peel the power and volume button unit out of its thin recess in the side of the frame. Remove the power and volume button unit. Remove the power and volume button unit.
手順 2  ¶
  • Use a pair of tweezers to gently peel the power and volume button unit out of its thin recess in the side of the frame.
  • Remove the power and volume button unit.
