メインコンテンツにスキップ
ヘルプ
iPhone XS Lower Speaker Replacement
Remove or replace the main loudspeaker on the bottom edge of the iPhone XS.
  • 作成者: Jeff Suovanen
  • 所要時間: 1 - 2 時間
  • 難易度: 普通
The iPhone XS uses both the primary loudspeaker and the earpiece speaker together to produce stereo sound. Use this guide to replace the primary loudspeaker at the bottom of the phone only. Replacing this speaker can help resolve issues such as loss of sound, poor sound quality, and distorted sound.
手順 1 Lower Speaker  ¶
Remove the five screws securing the two brackets below the Taptic Engine and main speaker: One 1.0 mm tri-point Y000 screw
  • Remove the five screws securing the two brackets below the Taptic Engine and main speaker:
  • One 1.0 mm tri-point Y000 screw
  • Two 1.3 mm Phillips screws
  • One 1.7 mm Phillips screw
  • One 1.8 mm Phillips screw
手順 2  ¶
The brackets are lightly adhered in place. Gently lift to unstick and remove each bracket, being careful not to bend it. If necessary, apply a little heat with a hair dryer or heat gun to soften the adhesive. (Putting an iOpener on the brackets is not recommended, as this may bend the spring contacts along the top.)
手順 2  ¶
  • The brackets are lightly adhered in place.
  • Gently lift to unstick and remove each bracket, being careful not to bend it.
  • If necessary, apply a little heat with a hair dryer or heat gun to soften the adhesive. (Putting an iOpener on the brackets is not recommended, as this may bend the spring contacts along the top.)
手順 3  ¶
Remove the 1.9 mm Phillips screw securing the speaker connector cover. Remove the 1.9 mm Phillips screw securing the speaker connector cover.
手順 3  ¶
  • Remove the 1.9 mm Phillips screw securing the speaker connector cover.
手順 4  ¶
Remove the speaker connector cover.
手順 4  ¶
  • Remove the speaker connector cover.
手順 5  ¶
Use the tip of a spudger to pry up and disconnect the speaker connector. Use the tip of a spudger to pry up and disconnect the speaker connector.
手順 5  ¶
  • Use the tip of a spudger to pry up and disconnect the speaker connector.
手順 6  ¶
When prying up the speaker, take care not to damage the speaker flex cable you just disconnected. If necessary, bend the cable toward the battery so the speaker has room to come out. Insert a spudger under the top edge of the speaker, near the edge of the iPhone's case.
手順 6  ¶
  • When prying up the speaker, take care not to damage the speaker flex cable you just disconnected. If necessary, bend the cable toward the battery so the speaker has room to come out.
  • Insert a spudger under the top edge of the speaker, near the edge of the iPhone's case.
  • Gently pry up and lift the top edge of the speaker slightly.
  • When reinstalling the speaker, check the position of the flex cable and make sure it doesn't get trapped underneath the speaker.
手順 7  ¶
While prying up the speaker, use tweezers to peel away the plastic bumper strip from the top edge of the speaker. If necessary, apply a little heat to soften the adhesive and make the bumper strip easier to separate.
手順 7  ¶
  • While prying up the speaker, use tweezers to peel away the plastic bumper strip from the top edge of the speaker.
  • If necessary, apply a little heat to soften the adhesive and make the bumper strip easier to separate.
手順 8  ¶
Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone. Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates. Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
手順 8  ¶
  • Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
  • Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
手順 9  ¶
Remove the speaker. The speaker's adhesive gasket is not reusable. Peel away any remaining adhesive residue with tweezers.
手順 9  ¶
  • Remove the speaker.
  • The speaker's adhesive gasket is not reusable. Peel away any remaining adhesive residue with tweezers.
  • To help protect against water and dust intrusion, replace the adhesive gasket during reassembly. Prep the area by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly. Install a new gasket onto the speaker, and then install the speaker.
