メインコンテンツにスキップ
ヘルプ
Lenovo Thinkpad Edge E545 Optical Drive Replacement
より良い紹介部分
より良い紹介部分
この紹介部分を完成し編集することでこのガイドを改良する
This guide will walk you through the steps needed to replace the optical drive on your Lenovo Thinkpad Edge E545.
  • 作成者: John Metzger
  • 所要時間: 2分
  • 難易度: とても簡単
手順 1 Optical Drive  ¶
Using the Phillips #000 screwdriver, remove the screw that holds the optical drive in place. It is found in a square indent close to the center of the back panel of the computer.
  • Using the Phillips #000 screwdriver, remove the screw that holds the optical drive in place. It is found in a square indent close to the center of the back panel of the computer.
手順 2  ¶
Use the end of the screwdriver to  assist in starting to  slide the optical drive out. Put it into the hole where the screw was removed.
手順 2  ¶
  • Use the end of the screwdriver to assist in starting to slide the optical drive out.
  • Put it into the hole where the screw was removed.
  • Push towards the direction the optical drive slides out.
  • Once it can grabbed by hand, slide it out the rest of the way.
