メインコンテンツにスキップ
ヘルプ
ZTE Quest n817 Motherboard Replacement
This guide will provide instructions on how to replace your ZTE Quest's motherboard.
  • 作成者: Eric Loureiro
  • 所要時間: 8分
  • 難易度: 普通
If you do need to replace your ZTE Quest's motherboard, this guide will take you through the process of opening your device and fully removing the motherboard.
セクション
ツール
手順 1 Motherboard  ¶
Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
手順 1 Motherboard  ¶
  • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
手順 2  ¶
Carefully pry open the back panel with the plastic opening tool.
手順 2  ¶
  • Carefully pry open the back panel with the plastic opening tool.
手順 3  ¶
Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
手順 3  ¶
  • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
手順 4  ¶
Pull back the tape encasing the brown ribbon cable connector.
手順 4  ¶
  • Pull back the tape encasing the brown ribbon cable connector.
  • Remove the ribbon cable from its socket.
手順 5  ¶
Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
手順 5  ¶
  • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
手順 6  ¶
Disconnect the coaxial connector in the bottom right corner of the motherboard. Disconnect the coaxial connector in the bottom right corner of the motherboard.
手順 6  ¶
  • Disconnect the coaxial connector in the bottom right corner of the motherboard.
