ヘルプ
Shark IONFlex 2X Motherboard Replacement
This guide will show you how to safely remove the motherboard from your Shark IONFlex 2X.
  • 作成者: Kendal Cler
  • 所要時間: 30分
  • 難易度: 難しい
This replacement guide uses a metal spudger, T20 Torx screwdriver, and a large plastic opening tool. This guide will show the user how to open the device casing, access the motherboard, and replace the motherboard.
CAUTION: Use care when using the metal spudger, as the edges of the tool are sharp and can cut you if you are not careful.
手順 1 Motherboard  ¶
Unscrew the six 18.7mm screws in the bottom casing using a T20 screwdriver. Unscrew the six 18.7mm screws in the bottom casing using a T20 screwdriver. Unscrew the six 18.7mm screws in the bottom casing using a T20 screwdriver.
手順 1 Motherboard  ¶
  • Unscrew the six 18.7mm screws in the bottom casing using a T20 screwdriver.
手順 2  ¶
Turn over the machine and lift the top casing off. Turn over the machine and lift the top casing off.
手順 2  ¶
  • Turn over the machine and lift the top casing off.
手順 3  ¶
Remove the large black plastic plug using your fingers and/or long nose pliers.
手順 3  ¶
  • Remove the large black plastic plug using your fingers and/or long nose pliers.
手順 4  ¶
Remove large white plastic plug using your fingers and/or long nose pliers.
手順 4  ¶
  • Remove large white plastic plug using your fingers and/or long nose pliers.
手順 5  ¶
Squeeze tabs and remove small white plug with two white wires coming out of it.
手順 5  ¶
  • Squeeze tabs and remove small white plug with two white wires coming out of it.
手順 6  ¶
Squeeze tabs and remove small white plug with white and black wires coming out of it.
手順 6  ¶
  • Squeeze tabs and remove small white plug with white and black wires coming out of it.
手順 7  ¶
Squeeze the three plastic caps enclosing the crimped connection of the red, black and yellow wires extending outward from the motherboard to release the wires from the grip of the plastic caps.
手順 7  ¶
  • Squeeze the three plastic caps enclosing the crimped connection of the red, black and yellow wires extending outward from the motherboard to release the wires from the grip of the plastic caps.
  • You may have to adjust how you are squeezing the plastic caps to get the connection to release.
手順 8  ¶
Remove the caps from the red, black and yellow wires to expose the three metal clamps. Remove the caps from the red, black and yellow wires to expose the three metal clamps. Remove the caps from the red, black and yellow wires to expose the three metal clamps.
手順 8  ¶
  • Remove the caps from the red, black and yellow wires to expose the three metal clamps.
手順 9  ¶
Cut the red wires extending beneath the metal clamp, right below the metal clamp holding the two wires together. Repeat process for black and yellow wires. Cut the red wires extending beneath the metal clamp, right below the metal clamp holding the two wires together. Repeat process for black and yellow wires.
手順 9  ¶
  • Cut the red wires extending beneath the metal clamp, right below the metal clamp holding the two wires together. Repeat process for black and yellow wires.
手順 10  ¶
Unscrew the two 11.8mm screws in the motherboard using a T10 screwdriver. Unscrew the two 11.8mm screws in the motherboard using a T10 screwdriver.
手順 10  ¶
  • Unscrew the two 11.8mm screws in the motherboard using a T10 screwdriver.
手順 11  ¶
Remove the motherboard. Remove the motherboard.
手順 11  ¶
  • Remove the motherboard.
