メインコンテンツにスキップ
ヘルプ
Blackberry RIM 7250 Back Housing Replacement
This guide will show how to remove back housing in the Blackberry RIM 7250.
  • 作成者: Noah Eckert
  • 所要時間: 2分
  • 難易度: 簡単
This guide will be useful in replacing the back housing for the Blackberry RIM 7250. For this guide, you will need a plastic opening tool and a Torx #6 screwdriver head.
手順 1 Back Housing  ¶
Remove  the four 10.7 mm Torx T6 screws. Remove  the four 10.7 mm Torx T6 screws.
手順 1 Back Housing  ¶
  • Remove the four 10.7 mm Torx T6 screws.
手順 2  ¶
Remove the two 5 mm Torx T6 screws. Remove the two 5 mm Torx T6 screws.
手順 2  ¶
  • Remove the two 5 mm Torx T6 screws.
手順 3  ¶
Hold the phone with one hand, with the bottom facing toward you.
手順 3  ¶
  • Hold the phone with one hand, with the bottom facing toward you.
  • For both clips, insert the plastic opening tool and push away from you.
  • You will hear a clicking sound for each clip that is released.
手順 4  ¶
Grab the back housing from the bottom and lift the housing away from you. Grab the back housing from the bottom and lift the housing away from you. Grab the back housing from the bottom and lift the housing away from you.
手順 4  ¶
  • Grab the back housing from the bottom and lift the housing away from you.
