メインコンテンツにスキップ
ヘルプ
DOSS SoundBox Speaker Replacement
より良い紹介部分
より良い紹介部分
この紹介部分を完成し編集することでこのガイドを改良する
In this guide you will learn how to remove and replace a faulty speaker in the DOSS SoundBox.
手順 1 Speaker Removal  ¶
Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body. Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
  • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
  • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
  • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
  • Using a Magnetic Mat throughout this process will help prevent losing screws.
手順 2  ¶
Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires. Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
手順 2  ¶
  • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
手順 3  ¶
Use a soldering iron to de-solder the two speaker wires from the speaker itself. The speakers are ready to be removed and replaced.
手順 3  ¶
  • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
  • The speakers are ready to be removed and replaced.
  • Ensure that the device is turned off when handling bare wire.
  • Soldering iron is very hot.
