ヘルプ
技術: How to Fix Sticking House Windows
De-stick house windows with silicone lubricant.
  • 作成者: Anna Handza
  • 所要時間: 5分
  • 難易度: とても簡単
This guide will allow you to quickly de-stick house windows in an efficient, and long lasting way with WD-40 Specialist Silicone Lubricant.
手順 1 How to Fix Sticking House Windows  ¶
Unlock the windows' sash lock.
  • Unlock the windows' sash lock.
手順 2  ¶
Slide a single window pane in its' opposite direction.
手順 2  ¶
  • Slide a single window pane in its' opposite direction.
手順 3  ¶
Apply the silicone spray where the window and channel connect if the window is stuck.
手順 3  ¶
  • Apply the silicone spray where the window and channel connect if the window is stuck.
手順 4  ¶
Apply a thin coating of the silicone spray onto the windows' channels. Apply a thin coating of the silicone spray onto the windows' channels.
手順 4  ¶
  • Apply a thin coating of the silicone spray onto the windows' channels.
手順 5  ¶
Slide the window up and down along the channel until the silicone spray is evenly distributed. Slide the window up and down along the channel until the silicone spray is evenly distributed.
手順 5  ¶
  • Slide the window up and down along the channel until the silicone spray is evenly distributed.
手順 6  ¶
Repeat steps 2 - 5 with the opposite window pane. Repeat steps 2 - 5 with the opposite window pane.
手順 6  ¶
  • Repeat steps 2 - 5 with the opposite window pane.
手順 7  ¶
Apply more silicone spray as needed. Apply more silicone spray as needed.
手順 7  ¶
  • Apply more silicone spray as needed.
