ヘルプ
Lenovo IdeaPad U410 Screen Replacement
Guide on how to replace a broken LCD screen on your Lenovo IdeaPad U410 laptop.
  • 作成者: Edric An
  • 所要時間: 5 - 10 分
  • 難易度: 普通
This screen replacement guide will show you how to replace your defective LCD screen on your Lenovo U410. You will need a Phillips #1 screwdriver and a metal spudger. Be careful when removing the plastic trim and connectors because you can easily break them.
手順 1 Screen  ¶
Make sure your laptop is turned off before disassembling. Power off the laptop.
手順 1 Screen  ¶
  • Make sure your laptop is turned off before disassembling.
  • Power off the laptop.
  • Using the metal spudger, gently pry off the black trim around the screen.
  • Metal spudger can be used, but using your hand will prevent the screen and the plastic border from any damage.
手順 2  ¶
Remove the six 3 mm Phillips #1 screws holding the screen to the laptop. Ignore the "Do not touch" label on the bottom portion of the screen. It will not damage the laptop.
手順 2  ¶
  • Remove the six 3 mm Phillips #1 screws holding the screen to the laptop.
  • Ignore the "Do not touch" label on the bottom portion of the screen. It will not damage the laptop.
手順 3  ¶
Lower LCD screen onto the keyboard. Find the gold connector on the bottom of the LCD panel. Gently grab the connector on both sides and pull the connector straight out.
手順 3  ¶
  • Lower LCD screen onto the keyboard.
  • Find the gold connector on the bottom of the LCD panel.
  • Gently grab the connector on both sides and pull the connector straight out.
  • Connector cable is very fragile. Use the least amount of force possible.
