メインコンテンツにスキップ
ヘルプ
Asus Eee PC 1201HAB Keyboard Replacement
This guide will teach you how to remove and replace the keyboard.
If you are having troubles with your keyboard, this guide will teach you how to remove and replace it.
ツール
関連部品
手順 1 Keyboard  ¶
Use a plastic opening tool and carefully pry the top panel from the base. Use a plastic opening tool and carefully pry the top panel from the base.
手順 1 Keyboard  ¶
  • Use a plastic opening tool and carefully pry the top panel from the base.
手順 2  ¶
Slowly lift the keyboard from the base. Disconnect the attached ribbon from under the keyboard. Disconnect the attached ribbon from under the keyboard.
手順 2  ¶
  • Slowly lift the keyboard from the base.
  • Disconnect the attached ribbon from under the keyboard.
手順 3  ¶
Remove the keyboard.
手順 3  ¶
  • Remove the keyboard.
