ヘルプ
Apple TV 4K Remote Battery/Charging Port Replacement
A guide to replace the battery/charging port in an Apple TV 4K's remote.
  • 作成者: Keenan Barber
  • 所要時間: 10 - 15 分
  • 難易度: 普通
This guide will show you how to access the battery and charging port in your Apple TV 4K remote for replacement.
手順 1 Remote Battery, Charging Port  ¶
Heat iOpener according to manufacturer's instructions.
  • Heat iOpener according to manufacturer's instructions.
  • Place over the face of the remote to soften the adhesive under the glass.
手順 2  ¶
Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top. Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
手順 2  ¶
  • Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
手順 3  ¶
Push front face forward to disengage plastic clips at the top of the remote.
手順 3  ¶
  • Push front face forward to disengage plastic clips at the top of the remote.
手順 4  ¶
Unlatch the connector that binds the touch screen and logic board.
手順 4  ¶
  • Unlatch the connector that binds the touch screen and logic board.
手順 5  ¶
Use tweezers to pull off the connector that binds the touch screen to the logic board.
手順 5  ¶
  • Use tweezers to pull off the connector that binds the touch screen to the logic board.
手順 6  ¶
Lift the face from the body of the remote.
手順 6  ¶
  • Lift the face from the body of the remote.
手順 7  ¶
Lift the latch holding back the connector to the battery. Use tweezers to disconnect the battery connector.
手順 7  ¶
  • Lift the latch holding back the connector to the battery.
  • Use tweezers to disconnect the battery connector.
手順 8  ¶
Remove the following screws using  a T3 Torx screwdriver:
手順 8  ¶
  • Remove the following screws using a T3 Torx screwdriver:
  • Eight 2mm screws
手順 9  ¶
Using a plastic spudger, gently remove the logic board from the case of the remote.
手順 9  ¶
  • Using a plastic spudger, gently remove the logic board from the case of the remote.
手順 10  ¶
Gently dislodge the battery from the remote case, making sure to avoid damaging the battery itself. The battery should be fully removed now.
手順 10  ¶
  • Gently dislodge the battery from the remote case, making sure to avoid damaging the battery itself.
  • The battery should be fully removed now.
