ヘルプ
Dell Inspiron 15-7548 Speaker Replacement
This guide will show you how to replace the speakers on the Dell Inspiron 15-7548.
Is the sound coming out of your laptop distorted or unclear? Consider using this guide to replace the speakers in your device.
セクション
ツール
手順 1 Speaker  ¶
Remove the ribbon cable by pulling it out.
手順 1 Speaker  ¶
  • Remove the ribbon cable by pulling it out.
手順 2  ¶
Remove the compression caps by using the spudger. Remove the compression caps by using the spudger.
手順 2  ¶
  • Remove the compression caps by using the spudger.
手順 3  ¶
Untangle the wire from the plastic clips and remove the speakers from the device.
手順 3  ¶
  • Untangle the wire from the plastic clips and remove the speakers from the device.
