ヘルプ
技術: Vertical Blind Repairing
進行中
進行中
このガイドは現在作成中です。最新の変更を見るために定期的に再読み込みしてください。
メンバーによる寄稿ガイド
メンバーによる寄稿ガイド
私たちのコミュニティーの素晴らしいメンバーがこのガイドを作成しました。これはiFixitスタッフによって管理されていません。
This guide will help you repair broken vertical blinds.
  • 作成者: Group 3
  • 所要時間: 5分
  • 難易度: とても簡単
Many houses, schools, apartments, restaurants have Vertical blinds. Most of the time those types of blinds tend to break or fall with the pass of the time. They are really easy to use and have a very good accessibility. We are used to recycling or substitute when something is breaking or in bad conditions. But, on this website ifixit.org, they gave us the idea to start fixing the stuff and not throwing it away or recycling them, because when we recycle not all of the material’s can be recycled fully and must be thrown away. So, we propose that this kind of blinds can be simply repairing. Just taking the blinds off and try to stick them and putting back into place. This required some materials, and this is an easy way to help the environment.
手順 1 View the problem  ¶
1. Identify the problem with the blind.
  • 1. Identify the problem with the blind.
手順 2 Removal  ¶
2. Use your hand to carefully remove the blind.
手順 2 Removal  ¶
  • 2. Use your hand to carefully remove the blind.
手順 3 Examine  ¶
3. Look at the part you took off and see if the problem is with the top part of the blind.
手順 3 Examine  ¶
  • 3. Look at the part you took off and see if the problem is with the top part of the blind.
手順 4 Material Ready  ¶
4. Make sure to have some glue or tape to fix the hole on top of the blind so you can be able to reassemble it.
  • 4. Make sure to have some glue or tape to fix the hole on top of the blind so you can be able to reassemble it.
手順 5 Patience  ¶
5. Wait a few minutes for the glue to dry.
手順 5 Patience  ¶
  • 5. Wait a few minutes for the glue to dry.
手順 6 Repair  ¶
6. Reassemble the blind in the same place.
手順 6 Repair  ¶
  • 6. Reassemble the blind in the same place.
手順 7 Finish  ¶
7. Test the blinds by moving them side to side.
手順 7 Finish  ¶
  • 7. Test the blinds by moving them side to side.
